Sumbit Delay to opimize Network traffic
Posted: Wed Aug 23, 2023 7:34 am
by virtualrepublic
we are using CGRU with 22 computers and a 1Gbit Network. I am actually doing tests with different packages and EEVEE to figure out the efficiency. I realized that submitting a job will cause all PCs to load the scene from our fileserver at the same time which has a significant impact on the render times, too. It would be great if we had an important feature that CGRU manages a load queue automatically or by setting a manual delay in seconds to prevent 22 computers from accessing the file server at the same time.
Thanks for considering!
Re: Sumbit Delay to opimize Network traffic
Posted: Wed Aug 23, 2023 9:03 am
On a root branch you can set "Max Tasks Per Second" parameter to 1-3.
It should not be a problem on a GigaBit and 22 renders, check your network speed by some test.
