Custom command for launching software
Posted: Sat Mar 26, 2022 1:00 pm
by vfxgeek
I'm working on Ubuntu which is not set to English, and because of that one Nuke plugin has a problem with commas and dots, and in the result it's causing an error.
A workaround is to launch Nuke with: LC_NUMERIC="C" ./Nuke12.0
To launch NukeX I have created a shell script:
LC_NUMERIC="C"
./Nuke12.2 --nukex
When I launch this from terminal the Nuke plugin works correctly. But when I launch Nuke from CGRU tray software list (which points to this .sh script) the plugin still causes the error. It seems like it's ignoring the locale change command.
Why can that be?
Lukas
Re: Custom command for launching software
Posted: Sun Mar 27, 2022 4:48 pm
Hi! Try to trace a script running. For example echo something:
#!/bin/bash
export LC_NUMERIC="C"
echo LC_NUMERIC set to $LC_NUMERIC
./Nuke12.2 --nukex
Also add "#!/bin/bash" and "export" keywords.
For testing better to launch terminal, go to cgru root folder, setup cgru and launch nuke command.
cd /opt/cgru
source ./setup.sh
nuke
Posted: Thu Apr 07, 2022 9:49 am
by vfxgeek
I've launched Keeper from terminal, to see what it's doing when launching software.
Aparrently it's not executing the shell script which I've created and set as the executable for NukeX, but simply it's running "nuke --nukex"
Posted: Wed Apr 13, 2022 4:47 pm
Hi! (sorry for a long delay)
If you want afanasy and keeper (cgru) to launch your own "nuke" command, you should add it to path.
But cgru on setup (in setup.sh) adds its own "nuke" and other commands in PATH.
So you should place a script in cgru root folder line cgru/setup_custom.sh, where you can:
export PATH=/path/to_your/bins:$PATH
And setup.sh will source it:
https://github.com/CGRU/cgru/blob/master/setup.sh#L29
See https://github.com/CGRU/cgru/blob/maste ... _README.sh
Another way that prefer some companies, is not use any software setup and launch scripts from cgru.
CGRU software setup and launch scripts main role is to show you how to setup, what you need to that, what environment matters.
