Permission issue while rendering
Posted: Tue Jun 22, 2021 10:59 am
I have dedicated machines for my render farm, all of them are working fine. They use a render user who has access to our output directory. But now I want to add my artist's machines on farm also, what would be the best possible way.
I tried installing cgru on artist's machine and started afrender service with render user login only. But still it is unable to write in that central output directory, farm is throwing these errors:
Any lead would be appreciated
Warning! Unexpected error while opening /home/render/.cgru/config.json.
Error: [Errno 2] No such file or directory: '/home/render/.cgru/config.json'
Unknown command: verification_id
Unknown command: license_id
Unknown command: lock
Unknown command: product_id
Unknown command: server_platform
Unknown command: support_expiry
Unknown command: houdini_version
Unknown command: available
Unknown command: count
Unknown command: ip_mask
Unknown command: display
Unknown command: }
Trying to set "Verbose Level" to 1 on mantra
Trying to set "Alfred Style Progress" on mantra
/out/bcd001_0183_test: RopNode.render: frame 1042.0; Started at: 14:38:44
[14:40:30] Generating Image: /outpath/file.1042.exr (1439x809)
[14:40:30] Plane[C]: 0 Cf+Af[4] (16-bit float)
[14:40:30] mantra: Mantra tile imager open failure: Tiled Image File: 0 file []
File: /outpath/file.1042.exr
[14:40:30] mantra: Could not open imager
Error: Failed to create file "/outpath/file.1042.exr : Permission denied".
103572 ThreadId=0x7f0aad3fe700: Fatal error: Segmentation fault
103572: Fatal error: Segmentation fault (sent by pid 103572)
-- TRACEBACK BEGIN --
Traceback from mantra 18.5.462 (Compiled on linux-x86_64-gcc6.3):
stackTrace()
signalCallback(UTsignalHandlerArg)
UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo_t*, void*) const
UT_Signal::processSignal(int, siginfo_t*, void*)
_L_unlock_13
(anonymous namespace)::system_error_category::~system_error_category()
__cxa_finalize
__do_global_dtors_aux
-- TRACEBACK END --
File "/cgru.3.1.0/plugins/houdini/hrender_af.py", line 315, in
ignore_inputs=ignoreInputs
File "/opt/hfs18.5.462/houdini/python2.7libs/hou.py", line 69031, in render
return _hou.RopNode_render(self, *args, **kwargs)
hou.OperationFailed: The attempted operation failed.
Error: Command Exit Code: 139
