Mantra frames per task doesn't work
Posted: Thu Oct 31, 2019 11:17 am
I have an issue, I couldn't solve myself. Basically if I set frames per task anything more than 1 mantra still renders 1 frame only. Say I put 2 frames per task. 2 IFD files are being generated correctly, and then mantra task finishes one frame only and marks job as finished.
IFD generation executable:
Mantra job seems to take into account only first frame and ignore $F4 variable:
And afwatch shows that job as done without errors, though mantra rendered one frame (screenshot):
https://drive.google.com/file/d/16fQ79K ... sp=sharing
frame 1-2
hbatch[hbatch]:1000 frames(1,2,2):
Command:
hrender_af -s 1 -e 2 --by 1 -t "_current_" "N:\PRJ\RND\18008_AzureTests\SHOTS\test\LIGHT\pig_oracle_test_open_shader_v012-mantra_render-_current_.1031-131341-596.hip" "/out/PIG"
Working Directory:
Files:
N:\PRJ\RND\18008_AzureTests\SHOTS\test\IMG\RENDERS\LIGHT_CHAR_PIG_V037\LIGHT_CHAR_PIG_acescg_V037_0001.exr
N:\PRJ\RND\18008_AzureTests\SHOTS\test\IMG\RENDERS\LIGHT_CHAR_PIG_V037\LIGHT_CHAR_PIG_acescg_V037_0002.exr
frame 1-2
mantra[mantra]:1000 frames(1,2,2):
Command:
mantra -V a -f N:\PRJ\RND\18008_AzureTests\SHOTS\test\CACHE\IFD\LIGHT_CHAR_PIG_V036\LIGHT_CHAR_PIG_V036_0001.ifd.sc
Working Directory:
