afanasy: Unknown command
Posted: Fri Jul 14, 2017 11:54 am
Greetings!
I have some strange issue with afanasy node in nuke 10.5 (in early versions was the same)
When i try to render through this node i get error on all hosts
HOSTNAME=somePC
LM_LICENCS_FILE='/usr/local/Nuke10.5v4/nuke.lic'
NUKE = '/usr/local/Nuke10.5v4/Nuke10.5'
Nuke 10.5v4, 64 bit, built May 4 2017.
Copyright (c) 2017 The Foundry Visionmongers Ltd. All Rights Reserved.
FileBrowser, Can't write favorites: No preferences path.
Temp directory = "/tmp/.afrender.nuke.win_0050_comp_v097.nk.0714-161607-816.win_0050_comp_v097.nk-v012.nk.25963"
Opening /teams/team_A/2016.07_Kolovrat/4_out/win/win_0050/2d/comp/scripts/win_0050_comp_v097.nk.0714-161607-816.win_0050_comp_v097.nk-v012.nk
Scene open error:
/teams/team_A/2016.07_Kolovrat/4_out/win/win_0050/2d/comp/scripts/win_0050_comp_v097.nk.0714-161607-816.win_0050_comp_v097.nk-v012.nk:
Removing temp directory:
If i use Submit Job menu - there is no problems
I checked, this file exist on this path (afanasy node created that file)
Local .nk file location get the same issue on machine, where it stored.
afanasy: Unknown command - i just cant understand what command afanasy dont know
I believe that afanasy is best software for me, i just want to understand what am i doing wrong?
HOSTNAME=somePC
Scene open error:
