When watch tries to do something, it usually prints some info in info line (status line) at the bottom of the dialog.
- is that folder correct?
Yes it is
You are showing tooltip.
- folder in tooltip correct?
Yes it is
What CGRU version you are using?
Latest 3.2.2 win build found here:
https://cgru.readthedocs.io/en/latest/d ... loads.html
everything is working fine, the only problem occurred pressing output icon: it popup explorer/documents folder, no render folder
