"Client has NOT closed socket first" in 2.3.0
Posted: Tue May 29, 2018 12:53 pm
by selsner
Hallo,
I am testing the current version 2.3.0 and in the server logs I get a lot:
WARNING Client has NOT closed socket first.
We are not using the web gui and I guess that you progammed the afrender to correctly close the socket. I have tried setting the option for SO_REUSEADDR to 1 according to https://stackoverflow.com/questions/106 ... c#10651048, but it did not help. Maybe you have another idea. I do not get the message when using "epoll". Is the epoll mode stable/better/tested ?
Thank you Sebastian
Re: "Client has NOT closed socket first" in 2.3.0
Posted: Tue May 29, 2018 3:00 pm
Here is a good description about all this:
https://github.com/CGRU/cgru/blob/maste ... ng.cpp#L18
"WARNING" just warns that client has not closed socket first in your pipeline.
It can be a problem on a huge amount of such clients.
But if you have several web browsers and may be some in-house tools, that communicates with afserver and can hold connection until afserver closes socket, it is not a problem.
You can always check whether your have a problem with it:
https://github.com/CGRU/cgru/blob/maste ... ng.cpp#L35
At work we are using EPOLL since it was implemented (2.2.3 2017.11.02). So i think that it is tested.
But "threaded&blocking" i/o is much more tested as it was from the beginning.
I think that non-blocking should be more effective on a huge amount of clients or networking with delays (not a local network). But it was not tested on such cases too.
Posted: Tue May 29, 2018 8:54 pm
by selsner
Thank you! I will check this and report back.
Posted: Wed Jul 24, 2024 2:43 pm
by selsner
Six years later, I am again seeing this a lot in our logs. It has been there in the meantime, but not so much (or I did not care, maybe ;) ).
I could identify this is often happening because of a call to python afnetwork.sendServer(json.dumps({"get": {"type": "jobs"}})). It seems like the size of what is returned by the server does matter a lot as I cannot trigger it with "small" requests. Does this make any sense?
