Problem here(Maya Redshift)
bellerfont
Post by bellerfont »
Hello there,
I have a problem, i cannot properly render my scene at all here are the screenshots
Error Host.jpg (120.66 KiB) Viewed 14029 times
Re: Problem here(Maya Redshift)
Try to launch task command within console (cmd.exe).
You can open console (terminal) from cgru keeper, or call setup.cmd in the cgru root folder first.
Try to use an english windows and ascii characters for work. MS Windows always produce coding errors.
bellerfont
timurhai wrote: Tue Jun 02, 2020 5:31 pm Hi.
Thank you Timur.
Great program, really appreciate what you are doing.Tremendous work. Well done
bellerfont
Well unfortunately on other PC's i have these problems
Wed 03 Jun 17:00.14: INFO Render registered.
Wed 03 Jun 17:00.15: INFO Started PID=7624 [maya:1000] farm2: iwtechi[camera1][frame 3]
Wed 03 Jun 17:00.18: INFO Finished PID=7624: Exit Code=-1073741819 Status=-1073741819
Wed 03 Jun 17:00.19: INFO Started PID=13180 [maya:1000] farm2: iwtechi[camera1][frame 6]
Wed 03 Jun 17:00.22: INFO Finished PID=13180: Exit Code=-1073741819 Status=-1073741819
Wed 03 Jun 17:00.23: INFO Started PID=1196 [maya:1000] farm2: iwtechi[camera1][frame 6]
Wed 03 Jun 17:00.26: INFO Finished PID=1196: Exit Code=-1073741819 Status=-1073741819
On almost any problem you should launch command in the console.
Copy command from AfWatch and paste in cmd.exe.
There is a russian forum: http://forus.cgru.info/
