Hello there,
I have a problem, i cannot properly render my scene at all here are the screenshots
Problem here(Maya Redshift)
- output.jpg (126.43 KiB) Viewed 14031 times
- Log.jpg (149.32 KiB) Viewed 14031 times
- Error Host.jpg (120.66 KiB) Viewed 14031 times
Re: Problem here(Maya Redshift)
Try to launch task command within console (cmd.exe).
You can open console (terminal) from cgru keeper, or call setup.cmd in the cgru root folder first.
Try to use an english windows and ascii characters for work. MS Windows always produce coding errors.
Thank you Timur.timurhai wrote: ↑Tue Jun 02, 2020 5:31 pm Hi.
Great program, really appreciate what you are doing.Tremendous work. Well done
Wed 03 Jun 17:00.14: INFO Render registered.
Wed 03 Jun 17:00.15: INFO Started PID=7624 [maya:1000] farm2: iwtechi[camera1][frame 3]
Wed 03 Jun 17:00.18: INFO Finished PID=7624: Exit Code=-1073741819 Status=-1073741819
Wed 03 Jun 17:00.19: INFO Started PID=13180 [maya:1000] farm2: iwtechi[camera1][frame 6]
Wed 03 Jun 17:00.22: INFO Finished PID=13180: Exit Code=-1073741819 Status=-1073741819
Wed 03 Jun 17:00.23: INFO Started PID=1196 [maya:1000] farm2: iwtechi[camera1][frame 6]
Wed 03 Jun 17:00.26: INFO Finished PID=1196: Exit Code=-1073741819 Status=-1073741819
On almost any problem you should launch command in the console.
Copy command from AfWatch and paste in cmd.exe.
There is a russian forum: http://forus.cgru.info/
