JSON Request for task
artem.lavilin
Post by artem.lavilin »
Hello! How to form a json-request for all information about current task (time start, etc)?
I looked at all the files in the examples folder, but did not find what I needed.
Try this:
	"get":
		"type" : "jobs",
		"block_ids" : [1],
		"task_ids" : [0],
		"ids" : [3]
But how to get the 'block_ids', 'task_ids' is not very clear.
Thanks in advance.
Re: JSON Request for task
Block and task id is just their number (array index), 0 - is the first, 1 - is the second, n-1 - is the last.
artem.lavilin
Does this mean if I want to get information about tasks I need to get a block_num and task_num and then iterate over them?
It's correctly?
task_num= task['task_num']
block_num= task['block_num']
job_id = task['job_id']
get = {
	'type': 'jobs',
	'ids': [job_id],
	'block_ids': range(0, block_num),
	'tasks_ids': range(0, task_num),
request = af.json.dumps({'get': get})
result, jobInfo = af.afnetwork.sendServer(request)
artem.lavilin
Maybe there is some easier way to get this information about task by Python Api?
You can open Web GUI and see network log to see how it works.
Also you can launch AfWatch in a terminal (linux), it prints json requests too.
If you need to get job all tasks, you can get job with tasks at once:
https://github.com/CGRU/cgru/blob/maste ... bs.json#L8
artem.lavilin
Thanks. I'll try look at the network log.
artem.lavilin
Sorry, I do not get the information I wanted.
I try request with block_id and task_id, but result is empty. I looked at the net-monitor.
If i use only block_id, i get result (i get info only about tasks_num, tasks_name, etc). task_id doesn’t affect anything.
How to get complete information about a specific task?
You can open it in GUI and see logs.
artem.lavilin
I need to see task through python.
Server has only JSON API. Python module (API) just helps you to construct a valid JSON objects.
