One of the computers in the local network refuses to render frames sent through Submit Job from manager computer. Other computers render without any problems.
It shows Exit Code -1073741819
This is the command it runs: mayarender -r file -s 1 -e 1 -b 1 -cam "camera1" -rd "O:\carriage" "P:\0_assets\0_props\carriage\2_shading\carriage_shading.0014.ma"
Afanasy info: https://pastebin.com/fnc5wfUi
I checked env variables, i checked if afanasy sees the software, i checked that the render from the computer itself works. Everything seems to be ok, but it still doesn't want to render.
Could you please help troubleshoot this?
Thanks.
Software: Maya 2019.1
Windows 10 pro x64 build 1903
cgru ver 2.3.1
Hello.
You want to say, that the same command
returns some different exit code on some machine?
Have you tried this command w/o Afanasy, just paste it in a console, and check exit code?
I went to afanasy terminal and ran the mayarender command and it just returns me the computer name.
In another computer render kicks in and completes successfully.
I see exit codes in terminal from render.cmd
- The one that works
- Terminal2.jpg (230.27 KiB) Viewed 45084 times
- The one that doesnt work
- Terminal1.jpg (83.04 KiB) Viewed 45084 times
So now you see your problem.
You should dig what is going on, what is the difference between computers.
May be mayarender script can't find Maya installation directory?
It seems like something is wrong with maya.
mayarender command is basicallu Render.exe called with arguments.
And Render.exe doesnt work either. Maybe i'll just wipe the OS
Ensure that it found Render.exe location.
