Hello
I have some problems collecting statistics from Athanasius
I did everything according to the instructions. Athanasius works
Database connected
Added PSQL and apache, in apache I registered the path to the cgru/afanasy/statistics/index.html
But when I open the link, I get lines of red code
What am I doing wrong?
OS Ubuntu 18.04
Afanasy 2.3.1
Afanasy, PSQL, Apache - one server
Afanasy Statistics
Afanasy Statistics
- aferror11.jpg (130.85 KiB) Viewed 115644 times
- aferror.jpg (54.59 KiB) Viewed 115644 times
Re: Afanasy Statistics
WARNING: SERVER ADDRESS ID - I changed the server address to ip, but this removed only the inscription about an unassigned ip
Have you installed libapache2-mod-php and php-pgsql?
(And restarted apache2?)
AAAAAAA
it was necessary to write just php, and I wrote from the instructions php5
Now I read that there is no php5, there is now php7
I did it, it worked, thanks a lot!
And another question, where does the statistics come from, from which file or folder?
It work now on php7.
Statistics pushes Afserver to PSQL database.
OK, But where is the data on the afserver, which then goes to the DB?
Afserver pushes data(a row) into DB on some event (task start, stop, job deletion, etc.).
Today I launched three tasks, they were completed, but there is no information about them in the statistics
Tell me, what could I miss?
- Annotation 2020-02-04 170749.jpg (141.75 KiB) Viewed 115584 times
- Annotation 2020-02-04 170748.jpg (136.29 KiB) Viewed 115584 times
In the database itself, rows and columns are created
- Annotation 2020-02-04 171213.jpg (116.77 KiB) Viewed 115583 times
- Annotation 2020-02-04 171212.jpg (107.24 KiB) Viewed 115583 times
Try to see server logs (afserver process output).
And firefox (web browser) console for errors.
