Afanasy Statistics
vdobrv
Afanasy Statistics
Post by vdobrv »
Hello
I have some problems collecting statistics from Athanasius
I did everything according to the instructions. Athanasius works
Database connected
Added PSQL and apache, in apache I registered the path to the cgru/afanasy/statistics/index.html
But when I open the link, I get lines of red code
What am I doing wrong?
OS Ubuntu 18.04
Afanasy 2.3.1
Afanasy, PSQL, Apache - one server
vdobrv
Re: Afanasy Statistics
Post by vdobrv »
WARNING: SERVER ADDRESS ID - I changed the server address to ip, but this removed only the inscription about an unassigned ip
Have you installed libapache2-mod-php and php-pgsql?
(And restarted apache2?)
vdobrv
Post by vdobrv »
AAAAAAA
it was necessary to write just php, and I wrote from the instructions php5
Now I read that there is no php5, there is now php7
I did it, it worked, thanks a lot!
And another question, where does the statistics come from, from which file or folder?
It work now on php7.
Statistics pushes Afserver to PSQL database.
vdobrv
Post by vdobrv »
OK, But where is the data on the afserver, which then goes to the DB?
Afserver pushes data(a row) into DB on some event (task start, stop, job deletion, etc.).
vdobrv
Post by vdobrv »
Today I launched three tasks, they were completed, but there is no information about them in the statistics
Tell me, what could I miss?
Annotation 2020-02-04 170749.jpg (141.75 KiB) Viewed 115587 times
Annotation 2020-02-04 170748.jpg (136.29 KiB) Viewed 115587 times
vdobrv
Post by vdobrv »
In the database itself, rows and columns are created
Annotation 2020-02-04 171213.jpg (116.77 KiB) Viewed 115586 times
Annotation 2020-02-04 171212.jpg (107.24 KiB) Viewed 115586 times
Try to see server logs (afserver process output).
And firefox (web browser) console for errors.
