Do you think that there will be support for kdenlive at all or is that not going to happen?
manamaster
Post by manamaster »
I use Kdenlive a lot and I was wondering if it was possible to integrate it into CGRU because it supports other software I use like Natron and Blender. If it is going to be added that would be amazing and I wouldn't have to deal with manually sending renders over to one of my PCs.
Re: Do you think that there will be support for kdenlive at all or is that not going to happen?
Afanasy can distribute over farm everything that you can describe via command line.
Some soft, like Blender and Natron has a build in Python (Python API) to create custom dialogs/nodes that can can construct and send job(s).
Even if soft has not any Python (API) you we can use AfStarter (http://cgru.info/afstarter) dialog to construct and send a job.
