Windows 10 not render
vdobrv
Post by vdobrv »
When I start Afanasy script for render my task does not appear in AfWatch, but there were no mistakes.
Someone faced a similar.
I`ll try C4d and AE
Re: Windows 10 not render
Too low information.
You should always specify CGRU version, client and server OS.
What soft you are using (if you can say it) and its version.
Step-by-step instruction what are you doing and how, like:
1. Launch Soft (using keeper or not).
2. Create a sphere.
3. Press that button.
Why Windows 10? You want to say that other windows versions (and may be some Linux) can render?
There is no special Windows 10 issues in Afanasy.
Most probably similar problem can be faced if you just installed a new OS and did not managed to setup Afanasy and Soft properly.
Or may be your windows was updated and somehow firewall blocks this.
