What can we do in this scenario?CGRU does not set the environment system wide and does not override any PATH, just appends few own.
On your system different processes has different PATH variable.
This is not a CGRU issue. And not for github. It is a common system administration question.
Try to ask some forum.
You can even ask me on a CGRU forum.
Cant find custom shell files
Following up our conversation
Re: Cant find custom shell files
How have you set PATH to see your nukeRender.sh for another user/shell?
Its already set in the PATH variable in etc/profile
``/etc/profile`` is invoked only for login shells.
If you login by afrender it will work, when init.d or system.d runs services it does not perform login.
As i told before, you can create a custom setup_myvars.sh in a cgru root folder.
And you can modify there PATH or just source /etc/profile file.
Better to create one ``setup_studio.sh`` to modify PATH. And source it from profile and from cgru folder.
sorry if i am asking too much.
how can we do this?If you login by afrender it will work
Yes, you can.
But much more better solution i described above.
This is how it should be?
I just source /etc/profile in that studio_vars
Do not modify native CGRU files!
It makes impossible to switch to the new version!
Here CGRU setup.sh sources any files matches setup_*.sh mask.
https://github.com/CGRU/cgru/blob/master/setup.sh#L25
So you should place any setup_abc.sh file and do anything you want with afrender environment.
Yup i did that source the path to profile but still giving me same error
What have you did, say step-by-step.
Have you restarted afrender service after it?
