Task - Browse files/Preview
Afanasy Watch Qt GUI.
Re: Task - Browse files/Preview
It seems that Blender uses "/" direction slashes and on Windows and on Linux oses, am i right?
You are not using paths map, as you have only Windows on workstations and renders?
In such case we should change AfWatch code, to make it to change all slashes to "\" direction, if it running on Windows.
As a temporary solution, you really can:
self.data["files"].append(afile.replace("/", "\\"))
This solution is right if you have Windows only environment.
elecstorm
Post by elecstorm »
It is Houdini, yes, it's linux-like path on windows.
We have only Windows on our workstations.
3dlp
Post by 3dlp »
Sorry but///... windows > where is the pathmapping file set location ?
Trying to config set output folder = no luck
testing explorer "\\IP#\folder name" works fine with winkey+R
Tkx !
Paths map is a common cofiguration parameter:
https://cgru.readthedocs.io/en/latest/a ... #paths-map
Config files location:
https://cgru.readthedocs.io/en/latest/c ... ation.html
3dlp
Post by 3dlp »
Sorry i am lost.
At render slave machines (server and slaves = all win OS)
I create a config.json on /cgru
{"cgru_config":{
"af_servername":"192.168.69.230",
"pathsmap":[
["//server/projects/","\\192.168.69.11\databases"],
["//server/tools/","/mnt/tools/"]
Server Projects path location is \\192.168.69.11\databases
But when i start watch and click output to open render location files
It open local Documents folder... :(
Any help is very welcome
1. JSON syntax is incorrect, you can use text editor with JSON systax highlichting.
2. "\\192.168.69.11\databases" - very strange for a server-side path.
3. If you are using MS Windows OS only, you do not need any paths map setup.
4. If you start explorer with a path that does not exist, explorer starts in the local documents folder.
3dlp
Post by 3dlp »
I mapped network drive \\192.168.69.11\databases to Z:\
If i run (win+R)
explorer "Z:\"
Folder \\192.168.69.11\databases popups on explorer. it is open ok.
But when i set Open Folder, command is still opening \\Documents
tkx in advance
"Set Open Folder ..." stands for file explorer program customization. Practically it needed on linux only, on windows native explorer almost always is used. So you should not touch this item.
(On linux you can set "nautilus @PATH@" to use nautilus explorer and @PATH@ will be replaced on the folder to open.)
AfWatch prints in the info line what folder it plans to open, is that path correct?
3dlp
Post by 3dlp »
You mean this ?
When watch tries to do something, it usually prints some info in info line (status line) at the bottom of the dialog.
- is that folder correct?
You are showing tooltip.
- folder in tooltip correct?
What CGRU version you are using?
