Afermer rendermanager
Qt QML GUI with OpenGL.
edwardtwiss
Re: Afermer rendermanager
Post by edwardtwiss »
Hi Sergiy,
I have tried running this exe with CGRU 2.2.2 and get the following error:
c:\Dev\cgru\afanasy\bin\afermer.exe
Version Of QT:  5.7.0
libpng warning: iCCP: known incorrect sRGB profile
  File "c:\Dev\cgru\python\lib\site.py", line 176
    file=sys.stderr)
SyntaxError: invalid syntax
It looks like it is trying to throw an exception but is unable to print the details perhaps.
I'm running it on Windows 10 Pro x64.
Edward
2.2.2 Windows release contains afermer.exe?
Or you build it yourself?
zaren
Post by zaren »
I build it myself, I'm going to include it in relsease
Hi, Edward,
It happens because I compiled it against python2.7 library.
Morrow I will compile boost and afermer against afansy python3
Cheers,
Sergiy
edwardtwiss
Thanks Sergiy!
CGRU windows release build against Qt-5.8.0 and Python-3.4.4.
Also it contains their libs. ( http://cgru.info/downloads )
If you are able to compile with this versions we can just put afermer.exe into 2.2.2 windows release archive.
bazarus
Post by bazarus »
I can't get it work. I try to start it with windows client (afanasy server 2.2.2 on Ubuntu 16) and i constantly get this error:
AFERROR: Msg::checkValidness: Version mismatch: Recieved(56) != Library(57)
And there is no jobs.
2017-06-29 13_54_03-No Jobs.png (127.9 KiB) Viewed 112658 times
There is 2.3.0 version in GitHub master branch, which is non-compatible with 2.2.2.
zaren
Post by zaren »
It was compiled for afanasy server 2.3.0. Sorry =)
I'm going to compile against 2.2.2. Shortly it will be presented.
Sergiy
zaren
Post by zaren »
This link for compiled afermer.exe Win7x64 for python2.7 for afserver 2.2.2 and Qt-5.7 but statically linking.
Bazarus, it can be for you =)
https://goo.gl/gQGW6M
Right now I struggle with python-3.4 and Qt-5.8 under windows. As soon as possible I will build it and share.
Sergiy
bazarus
Post by bazarus »
Thanks. Some svg icons missing. But work well with python2.7. Looks like its kinda limited now =)
2017-07-03 20_36_26-96% - Write1 __ AFermer __ Render Manager.png (151.28 KiB) Viewed 112603 times
